I have a small apartment size washer with the dyer on top. The washer will not drain. It spins but wont drain. I checked for clogs and found none. If I lower the drain hose at the back of the washer it will drain, but then it will not fill up with water, it continues to drain. If I raise the hose it will fill with water but will not drain.
What is the complete model number of the washer?
98702 model #
Model # 417.98702891
Serial # XEB5126380
Remove the washer front panel. Check for 120 VAC to the drain pump while the timer calls for drain/spin. Replace the drain pump if the voltage is correct.
- The drain pump AP4359998
Yes. If there is correct voltage to the pump but it does not work, then the pump is bad.
