Washer will not drain
Wash machine just started not draining, it will do everything else just fine, but when it goes on the spin cycle, it spins but a very slow spin and doesn’t drain. . . Also I have noticed when it is suppose to be draining. . . It smells like something is getting hot?
I tried to google before posting, I read about the switch for the closed lid, well mine still clicks every time i close the lid, So I do not think its that. . .
Please help,
&Thanks!
Remove the washer cabinet and the drain pump. Disconnect the hoses and check for any foreign objects inside the hoses and the pump. The hoses can be cleaned but the pump is better to replace.
There is the instructional video which will guide you through the disassembly process.
