It won’t spin out ???
Does it drain?
Does it spin or it does not at all?
Four words you posted is very short description on the problem.
Remove the washer cabinet and check the pump and drain hoses for a foreign objects inside. Check for a foreign objects between the inner and outer tubs.
— Begin quote from Gene;160819
THINK YOU i will try that
If there is no water left in the tub after spin cycle is over, the spin basket might not come up to full speed.
