Old kenmore washer wont spin
Washer wont spin. Only makes hummunig noise. New transmission, clutch. Could it be the drum assembly?
Remove the cabinet and check for a foreign object stuck between the inner and outer tubs.
Remove the motor and check it it would run on spin without a load. Post the results.
