kenmore washer/
need to replace the direct drive assembly but don’t know how to take motor off / or outside case . when lay on side oil comes out any directions thanks morris mdevore@inbox.com
If the washer was slinging out oil before, you have a bad tranny. Remove panel screws, tilt panel back, remove the spring clips, remove lit switch connector, and remove outer shell. Look at tranny for oil leaking. If so, you have a bad tranny.
it wasn’t on mine…i was an idiot and left it on it’s side and it drained out…can you refill the transmission? if so how?
The part number for the gear case oil is AP3072960
