5.5 yr old fridge Kenmore 106.54692300 (Whirlpool). Coils were dusty, but compressor unit failed hard in one day, no warm temp, etc.
Shouldn’t have but I spent too much to have someone come replace compressor here in California. Original compressor is Embraco EGZ 90HLP, the new compressor is Embraco FF 10HBX. The spec sheet I have on the FF 10HBX shows that it has approximate 1/5 HP. Can’t tell what the difference is from the Embraco site: http://www.embraco.com/ingles/produtos/02003.pdf
It’s been three days and I have heard compressor turn off only a couple times yesterday. The temp is the ref section varies from 35-39 degrees. The Ice maker has just about finished filling the whole tray, but refrig is not cycling off. [Should the fridge stay on constantly to fill the ice tray?] If the thermostat was bad, then wouldn’t the refrig section go down to 30 deg? BTW, my control board for turning ref of/on and changing freezer, ref temps went out last year. Controls levels are stuck at 4 for freezer (midrange) and stuck at 5 (one level above midrange) for the refrig.
On sears parts direct, the compressor listed is a comparable substitute. So, could the refrigerant level be low/high or the new compressor be a smaller size than original, 1/5 vs 1/4 HP? It is only 81 degrees Far in the house.
