The Kickstart capacitor bubbles out fluid when I press the contactor button/plunger. I priced an identical new capacitor and they are not cheap. The cheapest one I saw was around $180. The part# is 5162718 or KSTS324 or HC95DE042
324-356MFD
330VAC
I found a cheaper one on the Grainger website for alot less.
But, the specs are not identical. The specs are:
216-259MFD
330VAC
Made by Packard #44ZU51 $17.20 This one has a resistor soldered into the terminals like the Kickstart Capacitor.
I also found one with the following specs:
DAYTON
Round Motor Start Capacitor,300-360 Microfarad Rating,330VAC Voltage Item # 2MEP7 $55.50. This one does not have a resistor soldered into the terminals.
Can one of these or some other capacitor be used as an alternative to the original Kickstart capacitor?
Thanks very much
