Kitchen Aid KUDL02IRBS1 Does Not Start
I have a Whirlpool Dishwasher and the clean cycle flashes 7 times then pauses and then starts it all over again. Can you help me with a fix for this. Thank you Captain Andrews
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=du1055xtpb0
First try resetting it, see the tech sheet.
If it reoccurs
First I would check that the water temperature entering the unit is at least 120 degrees.
If OK
Check the heater and the hi-limit thermostat with a meter.
If OK
Check the thermistor with a meter.
If OK
Odds are that your control board needs replacing.
