Hi All,
I have a Kitchen Aid dishwasher (Kudp01dlwh3) that has power to the machine and control panel but no lights come on nor will it run. I tried replacing the thermal fuse but that didn’t work. Any ideas on what may be wrong?
Hi All,
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=kudp01dlwh3
Here is the tech sheet
I am assuming that you have checked for 120 volts from P7 on the board to P8 and P2-6 and in both cases power is OK.
Sounds like the control board is toast.
At least it is the most likely cause.
Denman - Thank you for the response. Which do I need?
Would it be the control panel?
http://www.appliancepartspros.com/part_details.aspx?part_id=3177379
or the Electronic Control Assembly?
http://www.appliancepartspros.com/part_details.aspx?part_id=3775964
Thank you again.
Most likely would be the electronic control board.
