KitchenAid 5 Door Fridge Leaking from Ice Maker When Using Water Dispenser
Model Number: KRMF706EBS01
When using the front door water dispenser, the water dispenses just fine. Comes on and off no problems.
However, when opening the door after dispensing water, I noticed water leaking from the top inside of the fridge where the ice maker dispenses ice into the bucket. It just drizzles out for a while.
https://ibb.co/qp2m7R4https://i.ibb.co/qp2m7R4/fridge.png
I removed the internal top liner of the fridge and located the dual water inlet valve and there is no water leaking directly from the valve. I disconnected the ice maker and don’t see any obvious leaking in the tubes or anything else.
The Dual Valve I examined: https://www.kitchenaidparts.com/PartDetail/Water-Inlet-Valve/WPW10341329/2683541?modelNumber=KRMF706EBS01
I’m pretty novice, so my first question is, should the ice maker side of the valve even be opening each time when dispensing water?
My current assumption is that the valve is faulty and the ice maker line from the dual valve is opening when dispensing water and then overflowing out of the cube tray.
First step I was going to do is replace the dual valve, but if that doesn’t work, what else would cause the ice maker to leak water only when dispensing water from the door?
*Note that I also ran the tech codes using the front LCD panel on the fridge, and did not receive any errors when testing the Ice Maker or the Water Dispenser.
Any help greatly appreciated.
Thanks!
