Icemaker inlet leaks when water dispensed at door
The original problem was that water was being dispensed through the door randomly. It seemed like it might have been happening when the ice maker was calling for water. So, I replaced the water valve thinking that it was bad. Once, I finished replacing the valve I checked the dispenser in the door to make sure it worked properly. It did, but now the problem appears to be that whenever water is dispensed through the door, the inlet tube for the ice maker dribbles out water and it overflows the tray and leaks into the freezer. Once the door dispenser stops dispensing water, the water no longer leaks out of the ice maker inlet tube. Any ideas?
Thanks.
