Water dispenced to door and icemaker at the same time
When I click water dispenser on the door of my fridge, the icemaker is also sent water which causes it to overrun with water.
I have just changed out the valve assembly and this did not fix the issue.
Help, I just spent 85.00 on a part I didn’t need to replace.
When I disconnect the wire harness on the valve for the ice maker feeder tube (the green), I can get water and there is not leak, but now the ice maker won’t fill.
Is this a control board issue? Any idea what part that is?
HELP!!!
