KitchenAid Cooktop—bottom right burner doesn't heat up
I have a 6-year-old Kitchen Aid electric cooktop. Exactly one year ago, when top was damaged, glass range top was replaced and it has worked perfectly since then. Control dial for this burner lites up and appears fine but one day, suddenly this one burner doesn’t get hot. It was expensive replacing the entire top. Is there someone that can tell me how to trouble-shoot to see if there are particular small part(s) that could be replaced rather than replace the entire glass top? Thank you.
I’ve been unable to download service manual for KECC508RPB00. Please help me do this. I have joined ApplianceDigest.com but when I go there to get manual it just throws me back to AppliancePartsPros web site. (I’m using a MacIntosh with Safari browser. Is that a problem?)
Also, does the part #15 you recommended (control board) come attached to ceramic cooktop if I opted to replace the whole ceramic top. Since ceramic top went out 6 days after warranty was up I was offered a discount on a new top and the new top is not much more than part #15. So, if I bought the new top, would it come with part #15?
You said to remove the "element". Please explain. Is this a round electronic unit separately attached to the ceramic cooktop? Does it come off?
Hello,
My Whirlpool thin twin will not drain or spin in the Normal setting, but will function normally in Permanent Press (drain and spin). So weird, any help would be appreciated. Does that sound like a lid switch issue? Thanks!!
Faulty timer.
http://www.appliancepartspros.com/whirlpool-timer-washer-3948357-ap3018981.html
Eric
Thanks fairbank56! I’ll give that a try.
I have a samsung front load washer that won’t drain. I replaced the pump and the circuit board but no luck. Washer goes through all cycles, except draining. Any ideas?
