— Begin quote from greatergraces@yahoo.com;335123
greatergrace already have dissconnected exhaust & air dryer is very hot,we already put part that we order on .
Greatergraces,
So much for the easy stuff,
I was not aware you replaced a part, what part did you replace ?
Now,
You’ll need to access the rear of the dryer, remove the back panel,
[LEFT]1. Unplug dryer or disconnect power.
2. Remove the rear panel [/LEFT]
[LEFT]3. To remove the thermal cutoff (TCO)[/LEFT]
[LEFT]a) Remove the two wires from the TCO
terminals.
b) Remove the hex-head screw, unhook
the end of the bracket, and remove
the TCO.
4. To remove the heater and inlet thermistor/
high-limit thermostat
a) Lift the locking tab and remove the
2-wire connector from the inlet thermistor.
b) Remove the wire connector from the
high-limit thermostat terminal.
c) Remove the two wire connectors from[/LEFT]
the heater terminal block.
Check for a resistance reading from each terminal to the flue box/housing. any resistance would indicate a shorted element and you’d need to replace the heater assembly.
[LEFT][FONT=ArialMT]d) Remove the two hex-head screws from
the heater assembly and remove the[/LEFT]
assembly.
[LEFT]e) Using a flat-blade screwdriver, pry the
inlet thermistor terminal off the heater
terminal, and remove the thermistor from[/LEFT]
the assembly.
[part]AP3094254[/part]
[/FONT]
The next step would be,
to access the main control board,
2. Turn off gas supply to dryer.
3. Remove the two mounting screws from
the rear of the console.
4. Lift the console off the cabinet and position[/LEFT]
it off to the side.
[FONT=Arial-BoldMT]To remove the machine control:[LEFT]
[LEFT]a) Disconnect the machine control board
connectors at P8, P9, P13, and P14,
then pull the red and black wires off the
heater relay terminals. NOTE: On dual
element models, also disconnect the
violet and black wires from the second
heater relay terminals.[/LEFT]
[LEFT]Once you’ve removed the wires from the heater relay,
with a multi meter, there should be no resistance across the two terminals on the relay, if there is, the relay is stuck closed, and causing the element to be on in all settings, and you’ll need a machine control board. [/LEFT]
[LEFT][part]AP4359310[/part][/LEFT]
[LEFT]I’m pretty sure you’ll find your problem in one of these areas, [/LEFT]
[LEFT]or the wiring to one or the other.[/LEFT]
[LEFT]Good Luck,[/LEFT]
[LEFT]
[/LEFT]
[/FONT]
[/LEFT]
