I have 2 identical dishwashers, same model and make. KitchenAid model, KUDP01FLBL2. One is mounted raised and one is counter level. The counter level has given me problems in the past not so the raised model. I had the control panel replaced on the counter model about 5 years ago. The unit has quit working again and about 1 1/2s of water is still in the bottom of the unit. I followed the reset procedures of first unplugging for 30 minutes and powering up and secondly pushing the prescribed buttons in the sequence required. Still will not power up. panel buttons will not light up or power up. Nothing. Anyone know if the control panel is bad or have any other ideas. When I opened the door after most of the water had dissipated there was a spoon and a fork loose in the bottom but not obstructing the float shut off.
Related topics
KitchenAid KUDP01FLSS won't start, will cancel | 1 | 3920 | January 11, 2011 | |
Control Panel | 1 | 1545 | March 26, 2010 | |
KitchenAid Dishwasher will not start | 2 | 2147 | March 12, 2012 | |
Kitchenaid KUDR01TJBL0 control board? | 1 | 99 | April 16, 2021 | |
KitchenAid panel problem | 2 | 1554 | February 13, 2012 |
