Kitchenaid double oven (Kebs277DBL8) code F2-E1
This double oven is about 15 years old, my first problem was two years ago the oven in self clean mode it dropped dead, I replaced the thermal fuse (4451042) and the thermal cut out (4452223) and sent the control board to have it tested and fixed.
The oven ran like GEM for the last two years all led’s were bright like new
                                   [COLOR="Red"]!!!  THE TROUBLE  !!!!
one day out of the blue the oven upon turning it on would run for 10 min (I think now it wont even run) and then shut down and the code F2-E1 would come up.
The owners manuel code explanation "keypad keytail not connected"
recommended repair
1.check for firm conection
2.replace key pad
3.replace control
I believe the control board is fine as I had it repaired Apr 2013, I think it may be the keypad issue switch membrane
the ribbon from the keypad has part WP #4451809 its unavailable !!!
[B]can any body suggest were to get a new or used keypad or who repairs keypads
Please let me know what wrong if you’ve had this problem
[/COLOR][/B]
