A few months ago my Kitchenaid oven started having problems igniting (Model number KGRS807SSS01). It would give the click-click-click noise and not ignite. This was sporadic and got worse as time went on.
I could manually ignite (with a wand igniter) the oven burner while it is doing the click-click-click (i.e. gas is flowing at that moment) and it would stay lit until it reaches the set point; at which point the oven burner turns off and will not re-ignite without manually igniting it again.
I did some research and found that the igniter for the bake burner (Manufacturer Number 9760229) is typically the culprit. I replaced the igniter and all was good for 2-3 days. Then it very quickly went from sporadic igniting to now it wont ignite at all! The broiler wont ignite either.
After replacing the igniter, I checked the resistance on the solenoids (broil and bake) on the gas valve (Manufacturer Number 9763716). I measured 208Ω across the one solenoid terminal and 207Ω across the other. I’m assuming that its not the gas valve since the tech sheet states 216 Ω ±30.
Now I’m not sure what to look at. I thought it might be the spark module (Manufacturer Number W10331686) but read that its a common mis-diagnosis. Any help is greatly appreciated!
Ed
