Kitchenaid ice maker not working, water dispenser works fine
ice maker worked fine up until a week ago. Water dispenser works fine. I believe emitter is fine - with door open and flapper valve open I get 2 red lights, pause, 2 more. With flapper valve on left pushed in I get solid red light.
There is no ice in ice tray currently. I haven’t heard the "call for water" that the maker would usually make but maybe I just missed it.
I don’t see any lights coming out of left flapper valve optical area - should I?
If water dispenser is fine then filter should be fine too correct?
How exactly do I see where the water line splits going to dispenser and going to ice maker? Obviously the dispenser part is fine - how do I see the ice maker part? Do I need to take off the back cardboard type panel?
