Icemaker will not produce ice. I removed it unplugged it and cleaned it. It had ice still in place, but would not eject it. Optics work fine, two flashes when blocked and steady red when not. Water to door dispenser good and strong. Will placing it back into freezer and reconnecting it cause it to cycle and indicate if it is fuctioning or could there still be a problem with the water valve? At this time I have reconnected it and it looks like the fingers have moved from pointing to the front to about the 4:00 position.
Thanks,
John
