Glass shattered in door while tightening loose handle… what do I need to repair/replace. The stainless part of door is fine, but glass attached to inside of it (outermost sheet of glass in door) is shattered. Do I need [AP4365327](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3082505&&model_id=264586&diagram_id=123378"]AP3082505[/URL], "Outer Door Glass Assembly (Stainless Steel)"… which looks just like my door without the handle… OR … can I get [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=4365327&&model_id=264586&diagram_id=123378), "Glass - door" (for about half the price)… which looks just like the glass attached to the inside of the metal ??? Any help would be appreciated…
thanks
thanks for the quick response… will check with parts dept and update when we find out. thanks again denman.
