Outer Door Glass Replacement
The exterior glass on my oven shattered. I bought a replacement piece but the glass is held in place by 4 pieces of adhesive tape plus a strip of adhesive rubber around the opening. I don’t see these ‘parts’ on the diagram and the local appliance repair shop doesn’t have a clue. Where can I get these required pieces?
If you click on the part below a new page will open, according to an answere in the Q&A section it should have come with the tape.
AP4365327
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KEMC308KSS04
Note that there are several 12’s door glass in the Oven Door Parts section depending probably on the units color/material so it is best to talk to the parts people at AppliancePartsPros
