KitchenAid Refrigerator not cooling
Lights come on inside but unit not cooling. No power to condenser fan or compressor. If I unplug cord from bottom of unit and jump power to fan side of plug, both fan and compressor come on and start cooling. I checked power to frige and freezer cold controls and have power on both sides. When i first plug unit in I hear a click in the defrost control board. I have power going in and out of that. Evaporator fan not running either.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KSRB25QGBL00
I am not sure about how/where you are taking your voltage measurements.
It is most likely a defrost board problem.
