Kitchenaid side by side fridge side is too cold
Evaporator and Compressor just replaced. Freezer is fine at 5 to 10 degrees but refrigerator side is at 20 degrees and everything is freezing.
I’ve turned down the thermostat located in the fridge side but nothing changes. Do I need to replace the Thermostat? Is the Thermostat or is it the Difduser and Control Board Kit @ $190-?
Alternatively, could I put tape over the air flow vent to partially block the rush of very cold air from the freezer??
