Kitchenaide dishwasher has no power. voltage and fuse is good
Hi, I’m looking for advice on troubleshooting my dishwasher. There are no lights on the control panel. I have 120 vac to the thermal fuse and the fuse is good. I’m leaning towards a bad control board as I have had intermittent issues with the indicator lights on certain functions going dim or not coming on at all. Any body have any advice?
Thanks, Ron
http://www.appliancepartspros.com/parts-for-kitchenaid-kudc10ixbl1.html
The model number is a 10I not 101.
Click on the control board and control panel in the parts for more info about them perhaps some of the Q&A will help.
Could be the control panel or the control board.
It is a crap shoot as to which one as there is not a good way to test the panel.
Perhaps try getting into the diagnostics.
Denman, Thank you very much for the information. I did get the dishwasher back up and running last night. I unplugged the connector on the door switch to check continuity when open and closed. It worked properly. I also unplugged all the connectors to the control board. When I reconnected everything the unit started working again. I must’ve had dirty connections as none appeared to be loose. I am saving the info you sent me for future use if needed.
Thanks again, Ron
— Begin quote from denman;865387
Parts for KitchenAid KUDC10IXBL1 Dishwasher - AppliancePartsPros.com
If it happens again you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
