I have a Kenmore Series 500 top loading washing machine (Model # 110.22352511). There is this continuous thumping/knocking sound during agitation (see for a video of it https://ufile.io/bjmf2wea ). Doing several internet searches might indicate a the tub bearing needs to be replaced or perhaps a drive belt? I know that the dampening rods likely need replacing since the washer will periodically shake uncontrollably during the spin cycle. might it be related? For what it’s worth, if I manually turn the tub, it makes this soft clicking sound as it turns.
If it is a tub bearing or drive belt, do you have a sense of how much it would cost for a repair person to fix it?
Any help would be appreciated. Thank you in advance.
