I have a Kitchenaid KSCS25FTMS00 Refrigerator that is less than 5 years old that is having some issues below - I’ve had 2 repairmen out and replaced a bunch but neither can get it to work.
NOT WORKING:
Lights - all lights inside the fridge
Icemaker - was working well until lights went out
Water Dispenser
Display in Fridge (that displays temp) - when the power is pushed it actually "counts" up to 5 then turns off
WORKING:
Refrigerator and Freezer (the actual fridge and freezer work just fine)
Outside Fridge Panel (the lights and buttons on the water/ice dispenser, but not the water/ice dispenser itself)
WHAT HAPPENED:
3 months ago the top light burned out (all others and water dispenser worked) and a new light bulb wouldn’t work - as I was replacing it I hit another piece with a metal screwdriver I was holding at the top light and saw a big spark then all the lights and the display board in the fridge went out
WHAT HAS BEEN REPLACED:
Control Panel in Back (not sure this did anything though - nothing changed with the operation - fridge/freezer still worked before and after the change, lights/icemaker/water dispenser didn’t work before and or after (but the repair man SWEARS it needed to be changed and was somehow defective - I’m not sure I believe him)
Control Board and Panel in Main Fridge - with the temp on it - the whole white piece with the control board were replaced - again, no change - same working fridge/freezer, no temp visible on the control panel though.
THOUGHTS: Would love to know anyone’s thoughts - the repair man said its probably the wiring somewhere as both control panels were replaced and that we need a new fridge - that is a lot of money less than 5 years later.
