Leak at main shaft to tub
Hello,
I want to change the washer tub seal, pn AP3156169, since I have a leak from the tub to the vertical shaft that turns the agitator. I can’t get the hub nut off (I plan to order the spanner wrench) so I can’t see any of the other parts to inspect whether I think other parts need to be replaced. Can anyone tell me what other parts (like the tub bearing pn AP3156169, or the tub bearing pn AP2045288, or others) that I should expect to need to order also? I’d like to avoid having to make multiple orders since I’d like to get my washer fixed as soon as I can.
Thanks!
