Leak Issues
Having a leak problem with my washer and looking for some advice. This actually started about a month ago when we first noticed leaking. After washes, I could feel a lot of water around the drain pump when I felt beneath the washer. So I took off the pump and found some chewed up change in there. I bought a new pump and replaced it. I also removed the tub, got to thee filter basket, and pulled a lot of change and other random objects out of there. Did some general cleaning and put it back together. Since then the washer has been running great, no leaks.
We did a few loads of laundry today. I just noticed a puddle of water coming from the bottom front of the washer. I tipped it over to look underneath. I can feel a lot of water sloshing around inside. Didn’t appear to be coming from the pumps. I cleaned up the water with a towel and put it back upright. I could immediately start to see water slowly spilling out the bottom front. Anyone know why that could be happening? Should there be water in there at all? Could the drain pump I put in be malfunctioning? I did a drain and spin cycle with nothing in it, but that did not seem to do anything. I am not very handy, and it took me a long time to get it apart down to the filter cover the first time. So I am not to excited about doing that again unless I have to. Just wondering if anyone could give me a reasonable guess what is going on based on my description and if it could be fixable. Thanks
A little more info needed. When do you notice the leak?
  1. when it is filling with water
  2. when it is washing
  3. when it is draining
    You say it is coming from the bottom front. Where exactly is that and can you actually see it coming out?
    Maybe a couple of pictures or a video can help us to help you.
    Pictures post here, video put on you tube then post link here.
