Leaking water pump?
Looked under the washer after noticing a leak in the front center of machine. I can see water drips from bottom of water pump. Could this be the problem? I wanted to know any advice before I go and order the part. Thanks
No, that is it. The pump is your problem. Tom http://www.applianceeducator.com/parts.htm
Pump should be here today! Thanks for the input. I hope that is all that it could be.
It will. Tom http://www.applianceeducator.com
Haha, that was just as easy as it gets! Thanks
