My Maytag is leaking water. The leak is coming from the hoses connected to the "rubber air gap fill injector tube" but it seems like all the parts look fine. The hoses are fine and the clamps were tight. The housing that the tube goes into that connects the two fill hoses (white) has 3 or 4 holes in it but they seem to be put there so I don’t understand why it has not always leaked?
Any help would be great.
Neil
[SIZE=3]This is the part that is most likely causing the problem.[/SIZE]
[Maytag Washer Leaking Rpair Guide](http://www.appliancepartspros.com/part_details.aspx?part_id=4025626&pn_=216201"]Part Details - WHIRLPOOL Valve, injector, part number: AP4025626[/URL]
[SIZE=3]To replace this part remove the hose coming from the valve at the air-gap. Inside that hose you will see this part it is just a rubber sleeve, pull it out. Inside of the rubber sleeve there is a hard plastic nozzle remove it and install it into the new rubber sleeve. Lube the edge of the rubber sleeve before pushing it back into the hose so that it won’t try to roll up on you. Then reinstall the hose onto the air-gap. Hope this helps! [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3][URL="http://www.appliance-repair-it.com/Maytag-washer-leaking.html)[/SIZE]
