Leaking water from ff door
i am having a water leak from the fresh food section of this frig. The temp in the freezer is a steady 6 degrees, and the FF section is reading at 38. Any ideas?
Sounds like the drain tube may be plugged.
I cannot really tell from the parts breakdown if the defrost drains directly out from the freezer or if the defrost water drips into a funnel like device st the top of the fresh food section and then out and down to the drip tray.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Be sure to unplug the unit while doing this.
Thanks. Any advice on getting to the drain. It looks like i have to take the freezer door off, and then remove the front of the freezer section. Are there screws hidden under the buttons on the front of the unit?
