Leaky LG Washer
So my washer is out of warranty and it decides to start leaking. It is a front loader LG. I have looked out on the web for repair ideas, but have not found a way to eliminate items. I took the top off and it is not leaking from the tray, it is not leaking from the front door, and the trap area is clean. It is leaking from underneath inside the machine. How do I determine where it is leaking from if I can’t get below to figure it out??? When I lift it up while it is going it stops and tells me it is an uneven load. Any suggestions? Thanks ahead of time.
Gus:D
