Remove top from LG front load Washer
LG Washer is leaking.
Im not sure how to get the top lid off to check for the leak.
removed the back panel and I know the leak is coming from the water inflow area. Once the water flow comes on I can hear it dripping. Should I remove the top by unscrewing the rear screws? Or are there clips in the front I can push a screwdriver into that will open the top from front to back?
Thanks,Jim
