LG WM2487HWM repair diagrams
I have an LG WM2487HWM front-load HE washer that is four and one-half years old. It has begun leaking, apparently from around the hot water solenoid. To access that part I need to remove the top but the way to do that is not obvious. So I have two question: 1) How do I remove the top? 2) Where can I get a repair guide?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520784
Here is a manual which should help with your repair.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=334
You may have to join the site but it is free.
That is the same diagram as on other websites. What I need to know is how to remove the top (or any other covers) so I can access the hot water solenoid.
Did you download the manual?
Page 29 shows how to remove the lid.
Thanks. That appears to provide the needed information.
