I just replaced the ENTIRE guts of my washing machine. It ran perfect until now. There is a leak on the floor on the right side(half) of the machine soaking the floor. This is the problem that started last time and forced me to fix the whole assembly. Are there any clues here, right side leak coming out the front. Just curious before I start tearing it apart. Thanks!
It looks as though the leak is coming from the transmission case. When small loads are done it doesn’t leak or not nearly as much. I am angry because I JUST replaced all the seals.
