The Temperature display for my oven is very faint. I can only see the temperature of the ovens if I put my hands around it very close. The time looks just fine. But for some reason the LED display for oven temp is almost not even there?
I have already replace the following parts to no avail:
Looks like the parts listing is screwed up.
The Control board you list looks more like a relay board than a control board.
Did the control board you received have the display on it?
Sounds like it could be the transformer (Item 6 in Section 7) is no good.
The problem here is that the display is OK when it shows the time.
We cannot get actual board schematics but I would have thought that the drive for the display would be the same for time and temp.
I could not see the tag in the picture of the part very good but it looks like it should be putting out 24 volts AC.
