LG front loader - "LE error code"
Hi I have a LG front loader model WM2301HR and the famous LE code.
Initially it was making all sorts of noise and grinding. I changed the rotor because the gear was worn smooth to the point of not turning (up to that point no LE error was showing)
After I replaced the Rotor " Part #: 4413ER1003BI " and started getting the LE code, and the machine was erratic making a grinding noise and giving me an LE code at the spin cycle.
I replaced the Hall sensor " Part #: 6501KW2002A " and now the LE code flashes about 1-2 minutes after starting the load. I checked the voltage for the wires that go into the Stator " Part #: 4417EA1002H " and I also checked the Stator itself and everything checks both voltage and resistance.
http://appliantology.org/gallery/image/733-wiring-harness-and-resistance-checks-on-the-hall-sensor-in-an-lg-washer/
Could it be the Stator? The control board? Maybe the new hall sensor I replaced "new" is bad?
I also took the machine apart and checked the bearings and spider just to be sure, but everything was in great condition.
I’m at my wits end and would greatly appreciate any advice to salvage this 4 year old washer.
How can I test the rotor position sensor (hall sensor) on the above machine?
