Hello,
I have pulled the front door off, no water is coming from the vent to the overflow. I took out the float censor and dried, there is no water coming from anywhere in the tank. It’s on of the two hoses right by the float censor that drains into the pan, any ideas what could be causing this? Usually triggers halfway through the 2 hour normal cycle. Thanks in advanced!
