LG Dishwasher Isn't Draining
Came down to the kitchen this morning to find water all over the floor. Looks like our dishwasher isn’t draining. I ran a quick rinse cycle and the water is staying the tub and leaking out somewhere from the bottom and coming out the front from under the door. I can’t seem to find a filter to clean and I’m not sure what the issue is. Does anyone have any suggestions?
Update
I tried running a Quick Rinse cycle and then cancelling it to run a drain cycle. I can hear the pump running but it’s not draining the water. I checked the end at the sink and that end of the drain is clear, so I’m going to assume that the drain plug is clogged at some point along the tube then?
