hello, after the wash cycle, the bottom of dishwasher is full of water.
is there a way for me to test that the drain pump is in fact the problem and needs to be replaced? the LG has a drain pump, which is part of a larger (more expensive) assembly of pump/motor. the drainage hose is clear.
Many thanks for any suggestions. -doug
