My LG Washer isnt really spinning when I start a load; it just kinda jitters back and fourth a bit. I purchased and installed a new Washer rotor position sensor switch, but it still is doing the same thing and I get the LE error code. Any ideas of what to do next?
LE means a drive thermal overload. This can be from a number of reasons. Do this first. Unplug your machine and open the door. By hand spin the inner tub, does it spin freely?
Yes, then your dive motor may be bad.
No, if you feel a restriction when spinning the tub it may be the bearings going bad or something stuck between the out and inner tubs.
