I have a new Drain Pump Assembly for my Neptune Washer. I need to know how to plug the clips back in. I have two white wires on one clip and one black wire on the other clip. Which one goes into the left clip and which into the right? The old Pump assemlby was marked but I did not mark them when I removed them.
— Begin quote from LSH0905;684295
Hello. Here is the procedures for replacing the drain pump right out of the service manual I hope this helps Thank you and good luck !
Hello. Here is the procedures for replacing the drain pump right out of the service manual after looking at the wiring diagram it does not matter which side they are plugged in to as long as the two white wires are on the same clip and the black one is on the other side Thanks and good luck !
