Locate Wiring Diagram
I have A Dacor ERD48 RANGE, the oven light turns on and off when it wants, sometimes rapidly or it will stay off for a period of time.
Thanx
Here is the wiring diagram for Dacor ERD48. Our experts may have some ideas on what to look for.
Also check the Diagnostic Test Manual (page 9). Let us know if you’ll need the correct part numbers.
:slight_smile: :slight_smile:
Just what I needed.
I think I have it figured out. There is an extension harness between the ribbon connector and the board. Wiggle test the plug and find the relay goes nuts. Cleaning the pins at the point where the harness and ribbon mate appears to have solved the issue.
Dave
