Seeing the Light(s) after Dacor Repair
I just installed a new oven control in a ERD48 Dual Fuel Range. Everything again according to specs EXCEPT for the oven lights which were illuminated in both oven. Moreover, all touch-screen pads worked fine, except for the Light pad.
On the control board, there is a three-prong connect for which I found no female mate. Not skilled enough reading schematics to confirm that that was the problem. But where else? (And where did that pesky ribbon run away to…?)
Thanks…
