Lost diagnostics and wash cycles
My washer would not spin and after running the diagnostics, it came up with a E47 code for the door lock sensor. I replaced the lock and now it only works (flawlessly) on the first 2 (Drain/spin;Rinse/spin) and last 2 (Delicate; Handwash) settings. None of the other wash cycles work at all (led’s go out and system turns off). I tried to run the diagnostics (which it worked before) and now it will not go into diagnostic mode. I tried plugging the old door sensor back in and it does the same thing with the wash cycles not working. Fridaire Customer service was no help at all and the wiring diagram provided by them does not match the unit.
