Loud banging noise at top final spin speed
Getting lots of vibration and load banging noise when washer goes into final
high speed spin cycle. Have removed top, rear and lower front panels.
Believe noise is coming from the two level shock absorbers. I can reduce the
sound and vibration levels slightly if I hold and try to steady the shock absorbers. Does this make sense? Shocks P/N is WH17X10001.
Price is about $94 each. Really don’t want to spend the money unless I have higher degree of confidence this will fix problem.
Go ahead and replace the shocks, if you buy from this site and they do not fix the problem you can return them.
Also, the price of $94 is for both not one.
Good luck.
