I’m getting very loud noise when washer goes into rinse or spin. The washer will agitate and pump the water out but will not spin on spin cycle. The coupler is in good shape and I just replaced the clutch today.
Thanks, TOMJB.
Well it can be the transmission, but the more likely problem is that the brakes are hanging up. Check them out, see the Sticky by Richappy at the top of the page for tech help.
