Low Water pressure at dispenser
Low water pressure at the water dispenser. Replacing the filter did not help.
When I remove the filter and put the plug in its place the pressure is fine.
I then put the filter back, and it works fine for about a day. The pressure is at a trickle.
There is no problem with the ice maker. The cubes are full size and solid.
