Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem
The water filter needed replaced as the red light came on. Around the same time
I notice that the water dispenser had lost a lot of pressure. It takes 5 minutes to fill a cup where as it was taking less than 10 seconds to do so. We replaced the water filter. Green light is on. However the water pressure is still very low. Everything has been working fine for the past few years (since we purchased). Need help figuring out which part to replace. In addition our ice maker is making hollow ice cubes. We noticed this around the same time as the water pressure being low in dispenser. We have not had any leaks or other issues. I don’t know if the water intake valve is bad or if it might be the filter housing or something else. On another note, the ice dispenser will dispense cubes but it will stop dispensing after a couple seconds and makes a loud grinding noise. Please help. Thanks.
