The Machine Is Putting Up A Code F-06. Which Is Drive Mtor Tach. Error. That Is Because Motor Is Not Turning. I Checked Motor Continuity And It Is Ok. I Don’t Know If It Is The Motor Control Unit Or Central Control Unit. I Checked Wire Connections Also And They Are Ok. Is There A Way To Check These Boards To See Which One It Is Without Replaceing One And Have It Be The Wrong One. These Are Not Cheap Parts.
Related topics
washer machine | 0 | 922 | September 18, 2011 | |
Washer will not spin | 4 | 1253 | June 22, 2012 | |
Whirlpool washer GHW9250ML0 not spin no error code | 5 | 1728 | January 29, 2012 | |
Need help with a stuburn F6 code | 11 | 4092 | May 9, 2011 | |
wtw5000dw1 Spin issue | 4 | 325 | February 14, 2020 |
